Need help spec'ing DAW build for a friend. (£540 budget)
The 8320 without a doubt. If he's only a light gamer why not save cash and get the 8320 spec with the 7790 and buy a bigger mechanical drive with the difference?
He is only a light gamer, which is why with the 8350, I spec'd a lower cost gfx card. As for storage space, 1TB will be more than enough for what he needs for the next 6months to a year and he also has a couple of external drives so hd space won't be much of an issue.
I thought the 8350 being 4ghz instead of 3.5ghz, along with more cores, would be a benefit when it comes to running audio programs which allow use of multiple cores. The gfx card in this instance wouldn't be required.
Games wise he only really plays counterstrike source/halflife on pc, but even with the 7790, he should be able to run the likes of bf3 with decent settings and fps.
