Need help to build a new pc.
Hi and welcome to the forum.
You really do need to state a budget.
There's no point in someone coming up with a £2,000 spec. if you can only afford £1,000.
Is your budget just for the base unit (excluding case) or do you need a monitor, keyboard, mouse, speakers etc?
What sort of games do you play?
If you already have a monitor what resolution is it?
Do you need an operating system?
Do you have any other components to re-use such as SATA HDD's, SATA optical drives etc?
Thanks for the quick replay, I should have explaned myself more sorry,
I think i spend about £1600, maybe a bit more if it worth it.
I dont need no speakers, keyboard and mouse has 2 of the 3 are new anyway.
My moniter is a 27 inch LG 1920 by 1080 but then again i might upgrade it at a later date.
I have windows 7 home basic already.
I could reuse my sata, ssd. I have two spinpoints f1 and a 120gb ssd.
My power supplie is 1000w but the wires are short so i could'nt really managed them properly.
The games i play the most are shogun 2 total war, battlefield and GTA
I know i do want the 7970 when i can get it.
That's a start.
What about the rest of the questions?
What's the rest of your system spec as it seems like you already have a lot of the components you need?
What make and model is your 1000W PSU? Do you know you can just by PSU extension leads don't you?
