need help to deside on this ?
27 Jan 2005
Letchworth Herts uk
Hi All I have a problem as to which way to go . I have had Seagate HDD Drives for years and never had a problem ,always very good ,but i,m hearing great things about the Samsung 1TB HDD and wondering if to go for them ,but i know the reliabilty of Seagate is very good and tested ,its kind of the old saying : if it an,t broke don,t fix it : anyone in my boat or changed HDD ? or are most HDDtoday very reliable ? help please thanks :confused:
Most of the large manufacturer's products are reliable and, as such, there really isn't much between the major players - the sands are always shifting in terms of the current "performance crown" but reliability-wise they will all be fairly close. If one of their products do fail they are usually covered by some sort of guarantee anyway. Just make sure you back up your important data because nothing, from any company, is 100% reliable.
For future reference:
, = comma
' = apostrophe
/grammar Nazi
Good luck.
, = comma
' = apostrophe
/grammar Nazi
Good luck.
thanks and that has helped me make up my mind ,and sorry about the crap grammar ! i did really pass O level English ha ha!
