As mentioned there's multiple ways to achieve it@Mcnumpty2323 I noticed on my bios I had to move a jumper so I can change voltage's.
I was wondering one thing so I'm certain I'm adjusting the right thing,I first Enabled Extreme Over Voltage because it say's it has to be.
I'm fairly certain I need to change the voltage by lowering with what's called CPU Core Voltage,is it CPU Core Voltage that I need to adjust and enter the lower voltage value there to undervolt the CPU.
I just don't want to do a bunch of tests only to find out I was adjusting the wrong thing.
My personal method is play with edc,ppt etc
So you're lowering the power supplied to the cpu
Less voltage,ampage should give better results
Plus this method has proven more stable for me anyway
Setting negative pbo and lowering cpu voltage
I found time consuming
And more likely to crash
