Need Help with £2500 complete gaming pc
6 Mar 2009
Flintshire North Wales
Hi all,
Been looking at forums for a while and now am looking to purchase as my system has finally died.....
my old system was a X2 4800+.msi Diamond K8N. 2x xfx overclocked 7800gtx. 19" tube monitor, 2gb crosiar extreme ram. 400hz i believe. audgy 2 sound card and 7.1 creative speakers.
This has last me a long time as all was top spec when i first bought..
I am now looking to do the same.... I have built computers before but might get one built for me... how much do OCUK charge for this?
So to the build....
I know that I want everything.... New monitor, Key Board, Mouse, Speakers, Case etc
With the monitor I'm looking at 22-23" (pc in bedroom wife wont have to big as 48" plasma already on wall lol) I also want a hdmi port as i believe this is future... Full HD would be nice
Key board mouse looking at G15 and G9. These any good?
Speakers 5.1 nothing big tho...
Case dont mind something looks good... have thermaltake armor at mo so size not issue...
I will be looking at overclocking so dont realt want to waste £1000 on i7 965.
Also really want water cooling! for looks and sound.
so any help guys?
thanks
Maybe go SLI?
really looking at water cooling also and key borad mouse etc? is SSD worth it or just 2 SATA in raid?
Will OCUK build this if so what do they charge?
SSD unless u can afford it just get SATA ll drives even velociraptors in RAID and u will be flying!
siumatfung, delete that competitor ASAP! I'm sure if you get in contact with OCUK they will be able to help with the pricing etc.
This is pretty much it, full watercooling, Single loops for GPU/CPU for max cooling. HDMI monitor, 2 F1's in Raid 0, GTX 295 etc, bit over budget tho.
£2500 on a gaming rig? the worlds you're oyster with that ammount of cash. I'd skip the normal hard drives if i were you and consider buying a 120GB+ ssd speed up you're overall system speed aswell as games.
If your thinking about building Ring OcUK tomorrow see what they could do for you.
Personally i wouldn't spend £500 295 not worth the extra especially on a 22" get the 4870 X2 or even a 4870 1024Mb would handle it fine.
Personally, wouldnt go watercooling. A good air cooling set up with Noctua case fines be fine.
I will post up a spec on something similar i would build with that budget. Only wish at the moment i had that much to blow on a Computer
