Need help with building my PC
29 Nov 2008
Well, just built, well nearly built my PC, got all the stuff in, just am not sure on where all the parts plug into, can someone tell me where evrything goes?
Im really stuck, please help.
Wow you just bought all the parts and didnt have a clue as to what parts go where or are compatable.? you will have to tell us the make and model of all your new hardware to make sure they are compatable, cause if there not an we tell you to do something and it goes wrong.....thats a hell of a lot of money down the drain :0
Google it mate, there are about a gizzillion guides.
My top tip, make sure you put the spacers in between your case and motherboard!
The spacers are called "standoffs" and I think it's a particularly important step.
When you're attaching them to the case you want to get them nice and tight, otherwise they'll spin when you try to screw the motherboard to them.
But yeah, loads of guides available. Good luck!
they only really spin (which is very annoying) when UN-screwing the motherboard screws, best to prep ahead though...
Yeah, but if you're screwing one in and it doesn't go in right, or you need to take it back out a little to allow the rest of the screws to go in.... that's when it causes a problem :P
but surly your screwing the screw in clockwise and if the stand-off is loose, turning the screw a few turns will tighten it.! but lets not bicker.!
JUST MAKE SURE THERE ON TIGHT IN THE FIRST PLACE AND IN THE RIGHT POSITION FOR THE MOTHERBOARD FORM FACTOR
LOL
:p
