- 9 Jul 2008
- Bristol
Hi as i will be doing most of my photography (skateboarding) close up, and i would like to get the best angles, i will need to use a fisheye with preffered 180 degrees viewing angle. I do not want a add on to my normal lense, i want a proffessional Fisheye that goes straight on the body of my D80.
I have been looking at the Sigma 8mm f3.5 EX DG Circular Fisheye Lens or the Nikon 16mm f2.8 D Fisheye Lens
I want to know if there are any better fisheyes, i do not want to spend more then £700 on a fisheye and hope you could get a better deal for me.
It also will need to fit on my Nikon D80 and easy to use for a noob like me
Thanks in advance
Thanks in advance
