I just built my new pc
I installed windows 7 but i cant get my gtx570 to work. the fans are spinning but when i connect my hdmi into it nothing appears on the screen.. if i plug the hdmi into the motherboards hdmi input it shows the screen.
I have gone to graphics options and it doesn't show my gtx570 only the intergrated gpu thingy. (Asus P8Z68-V PRO)
Does anybody know how to disable the onboard gpu so i can use my gtx 570 as as my main graphics.
Edit: I'm using 6 pin power connector for the gtx570. should i plug in the other 2 pin connector to it or not ?
Thanks
Thanks
Will let you know in a mo.
Thanks guys for your help i appreciate it.
