Need help with laptop specs
24 Feb 2015
So i recently built my gaming pc, which was a complete joy! So i wanted to get a laptop, but without building one myself. Its gonna be just for the likes of youtube, general internet stuff, films and music too. So was wondering what kind of specs would be best for best audio and picture quality as well as being able to run pretty fast. Im looking to spend at most £400-450.
I'm thinking myself at an asus with an i3, 8gb ram ( i know thats plenty more than what i need the laptop for), 500gb hard drive or lower. I aint too well versed in laptop parts, if they are good or what not cause i aint never delved into there too much, hence the help!
Thanks guys!
PC Specs:
CPU- i5 4670k
GPU- GTX 770 2GB
Mobo- Z87X UD4H
RAM- 8GB Corsair Vengence 1600Mhz
Psu- Corsair AX860i
SSD- 1x120GB 840, 1x250GB 850
HDD- 1TB Western Digital Black
Cooler- H80i
Case- Corsair Carbide 500r
for general stuff i think you can get at least an i5 for your budget. I am pretty most entry level laptops can do what you've described so really it all comes down to size and weight. I would tho op for an SSD even if its a small one. Makes a hell of a difference. Most laptops come as standard now or maybe you could swap it out and get a usb 3 enclosure for the hdd.
However, when you say audio what do you mean? good speakers? as for picture quality do you mean resolution or screen type?
Good luck
Good luck
I was think an ssd cause its certainly fast, only problem is that they are usually only 120gb in my price range so not much room to play. And in regard to sound i meant good speakers, and screen type is hopefully 1920x1080p, but i'd be happy enough with 768.
