- 5 May 2020
Hi so i had a 1050ti and AMD fx 8350 and i decided to upgrade to a 580 8gb,i valorant and fornite and the bottleneck from my cpu is so bad i now get anything between 70-110 on low settings same when i max them out!! what should i do downgrade to 570 8gb or buy a cpu cooler as i still use the stock one and OC my cpu ram ETC to fix it?.
but its annoying as my 1050ti was around £90 my 580 is around £180 and its even worse
