i put the one that came with my CPU on, then didn't realise till i had put it all together that i hadnt fitted the one you recommended haha
do you recommend that i put it on?
he still browses the forums i think.
Yes, it'll be cooler and quieter
You'll be fine with the stock cooler. Just install the Themis when you have time, it will be better if you want to OC the Cpu.![]()
I think i am going to give this ago at the weekend, will i have to remove the motherboard completely? don't suppose you know of a good video to help as everyone i search for on YouTube is in German and i was no good at that subject in school :/
You will need to make sure you have some thermal paste remover, as you will have to clean the old paste off.
Something like this:
YOUR BASKET
1 x Akasa AK-TC TIM Clean CPU & Heatsink Cleaner £5.99
Total : £9.90 (includes shipping : £3.26).
Here is a guide on removing the heatsink for Socket 1155. It will be the same for 1150 as well.
http://www.pcstats.com/articleview.cfm?articleid=2677&page=6
Just use some soft tissue. Or go down the Chemist and buy some Isopropyl Alcohol 50ml.
will normal alcohol not do? got plenty of that in the cupboard :L
In all seriousness though guys thanks for the help!
Also, which way should the fan be facing? towards the back or the front?
