Need help, with new PC
1 Apr 2016
My PC recently died on me, RIP buddy.
Im a total noob, I had that thing 7 years and only thing that I ever replaced was the PSU.
Im now in need of a new one. The main purpose of it is for playing online poker. I want to be able to play on multiple poker sites, up to 20 tables, with a few of other programs running, discord, spotify, skype, google chrome, plus a stats tracking program called holdem manager 2, which tracks/stores hands and updates in real time and gives you info via a HUD, which uses PostgreSQL(2?). Plus I want it to run 3 monitors.
I already have the monitors and mouse/keyboard and speakers.
So I want something that can do all that smoothly. Im in England, I would like to spend £450 - £550. If need be I would have a go at assembling it myself, but would prefer something thats already built.
I hope this is in the right place, if not, please direct me to the right place. Thanks for any help and I will do my best to provide any more info thats needed.
Build Time Standard Build Systems - Dispatched within 7 working days
Warranty OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour)
Security Software ESET Smart Security - Trial Key
Lighting Not wanted
Memory Team Group Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01)
CPU AMD Piledriver FX-4 Quad Core 4300 3.80GHz (Socket AM3+) Processor - Retail
Case BitFenix Neos ATX Tower Black/Black Window
Optical Drive Not wanted
Operating System Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Graphics Card MSI Radeon R7 250 OC 2048MB GDDR3 PCI-Express Graphics Card
Primary Solid State Drive / Hard Drive Samsung 120GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E120B/EU
Storage Mechanical Hard Drive Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
WIFI TP-Link 300Mbps Wireless N PCI Express Adapter (TL-WN881ND)
Sound Card Not wanted
How does this look? Do I need a sound card? I dont see that as an option in other configurations. Can this run 3 monitors?
What do you mean 'I suggest multiple monitors' ? quartz? My last PC ran 3 monitors, one of them using a USB adapter and was only used for tournament lobbies. I want this one to not have to use that adapter.
Any more help with this would really be appreciated.
Simply that for what you want to do, having multiple monitors will increase your productivity. Post #4 indicates your interest in such but doesn't actually say that you already have them. Many motherboards support up to three monitors (often VGA, DVI, and HDMI). You don't detail the motherboard in post #4 but the R7 250 does support three monitors (typically VGA, DVI, and HDMI) and there may be versions with differing outputs.
So, which outputs do your monitors support?
Yes I already have 3 monitors. One has VGA and HDMI and the other 2 have VGA, DVI and HDMI.
And yea I was unsure if the above could run 3 monitors, so good to know that it can, thanks.
Is the processor in the above ok?
