Need help with this problem that i cant solve
28 Dec 2010
Problem
Been trying to overclock this set up for a long time now and its always failed no matter what settings i try! The problem is that when i overclock it and turn it off when i'm finished with it and then go back on it hours later it will fail to load past the "Starting windows screen". The only way to get passed this screen is to remove the PSU cable, hold down the power button for 10 seconds or so and plug it back in and it starts up fine.
Things i've tried
- Latest bios and drivers
- Removed cmos batter for 9 hours
- 50 runs of Linx and it passed
- 2.5 hours of prime95 without errors
- 7 hours of Memtest86+ and no errors
- WD Diagnostic
- Windows Memory Diagnostic
- HD tune Pro
- Changed power cable
- Changed ram around in different slots
Pc Specs
- Intel i7 930
- Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel DDR3
- Asus P6TD deluxe
- Ati 5970 XFX Black Edition
- Windows 7 64bit
- Titan Fenrir Cooler
- Corsair HX 750W ATX Modular SLI Compliant Power Supply
Overclock settings
AI Overclock tuner: Manual
CPU Ratio Setting: 21
Intel (R) SpeedStep (TM) Tech: Disabled
Intel (R) Turbo Mode Tech: Disabled
BLCK Frequency: 181
PCIE Frequency: 100
DRAM Frequency: DDR3-1451MHz
UCLK Frequency: 2903
QPI Link Data Rate: Auto
DRAM Timing Control:
1st Information :
CAS# Latency: 9
DRAM RAS# to CAS# Delay: 9
DRAM RAS# PRE Time: 9
DRAM RAS# ACT Time: 24
DRAM RAS# to RAS# Delay: Auto
DRAM REF Cycle Time: Auto
DRAM Write Recovery Time: Auto
DRAM Read to Precharge Time: Auto
DRAM FOUR ACT WIN Time: Auto
DRAM Back-To-Back CAS# Delay: Auto
2nd Information :
DRAM Timing Mode: Auto
DRAM Round Trip Latency on CHA: Auto
DRAM Round Trip Latency on CHB: Auto
DRAM Round Trip Latency on CHC: Auto
3rd Information :
DRAM WRITE To READ Delay (DD): Auto
DRAM WRITE To READ Delay (DR): Auto
DRAM WRITE To READ Delay (SR): Auto
DRAM READ To WRITE Delay (DD): Auto
DRAM READ To WRITE Delay (DR): Auto
DRAM READ To WRITE Delay (SR): Auto
DRAM READ To READ Delay (DD): Auto
DRAM READ To READ Delay (DR): Auto
DRAM READ To READ Delay (SR): Auto
DRAM WRITE To WRITE Delay (DD): Auto
DRAM WRITE To WRITE Delay (DR): Auto
DRAM WRITE To WRITE Delay (SR): Auto
CPU Voltage: 1.27500
CPU PLL Voltage: 1.88
QPI/DRAM Core Voltage: 1.35
IOH Voltage: 1.20
IOH PCIE Voltage: Auto
ICH Voltage: 1.20
ICH PCIE Voltage: Auto
DRAM Bus Voltage: 1.64
DRAM DATA REF Voltage on CHA: Auto
DRAM DATA REF Voltage on CHB: Auto
DRAM DATA REF Voltage on CHC: Auto
Load Line Calibration: Enabled
CPU Differential Amplitude: Auto
CPU Clock Skew: Auto
CPU Spread Spectrum: Disabled
IOH Clock Skew : Auto
PCIE Spread Spectrum: Disabled
Advance CPU Settings
C1E Suppport: Disabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
Intel® Virtualization Tech: Enabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
Intel (R) HT Techology: Enabled
Active Processor Cores: All
A20M: Disabled
Intel (R) C-STATE Tech: Disabled
It works fine on stock settings and its a pain in the arse having to wait 6+ hours or so to turn it back on to test if i get the problem, ive tried lower overclocks and i get the same thing.
I mean when i turn off the pc and go to bed or whatever then try to start the pc up again when i next want to use it. I can go back into the bios and reset it to stock and it works fine but i want it to use the overclocked settings but it freezes on the starting windows screen no matter what kind of overclock speeds i try.
