need help
23 Nov 2004
hi im running a watercooling setup,and thought id have a go at overclocking my cpu,i have a Athlon 64 3000+ skt 754(newcastle) on a asus k8n4-e deluxe.ive managed to clock it to 2347.3mhz (260*9 @ 1.53v)
my problem is that i cant get past 260*9,ive tried everything but it wont post when i put it past 260 even if i lower the multiplyer,and up the voltage.
ive tried 1x 2x and 3x settings but it still does the same.ive tried 133 and 166 divider but i still cant get past 260x9 even if i lower it to 8 or 8.5 with 265 it still wont post.i noticed that if i put my vcore up any further than 1.55v the system just restarts then wont post so i ave to cmos it.do you think its the max ill be able to get or is there any way round it.should i be able to get more from it as its running at 2347mhz at the mo.cheers
Have you lowered the htt multi to 4 or 3?
If you make your posts a little easier on the eyes in future you might get more reponses... ;)
