need help
4 Jul 2009
Kilham, East Yorks
hi, my friend needs a new pc, his budget is £500, but he also needs keyboard, mouse and monitor, he mainly uses it for WoW, thanks
I know, thats what Ive told him, and I'm not to sure about that old parts, because his keeps breaking down, so maybe only the hard drive, and dvd drive can be re-used
nope, it has a OEM copy of xp, and the case is basicly useless, I have told him he will have to spend more then £500, but thats all he can afford at the moment
and his monitor wont keep him going for a while whilst he saves?
im sure you could probs buy an off the shelf pc for £300-£350 and then use the rest for a gfx card, but wouldnt be the way i would go.
well I'll ask him about the monitor later, I have got a spare 19" 1 I could lend him, so that would give more budget for the pc
for £500 for a tower he could scrape something together, but its not going to be great.
unless he looks second hand for some parts as suggested.
well, I haven't looked at his pc, but by the sounds of it, anything new'ish is gonna be a lot better then his
If you can use the copy of XP and your monitor he could get away with:
