Need help
30 Jan 2011
hi I've got a problem just started my cpu cooler is new it was amazing at start keeping stuff really cool but since I installed my new graphics card it just stopped working.
My cpu is getting so hot it crashes my pc when I turn on my pc back on it runs fine cpu cooler spins nice an then it seems to stop.
Then it wont come back on when I game so I end up crashing as cpu gets to hot what's gone wrong please help someone I've tried speedfan but cant seem to get it to work
This is my cooler its brand new well few weeks old like I say when I start the pc up it runs fine
https://www.overclockers.co.uk/noct...pu-cooler-with-two-nh-a15-fans-hs-026-nc.html
my psu is pretty new aswell
https://www.overclockers.co.uk/evga...plus-gold-modular-power-supply-ca-012-ea.html
only thing that's old is the motherboard an cpu they are a good few years old new maybe there failing me
A way to rule out motherboard PWM isuues, i'm assuming that you have connected the fans to the motherboard header, is to use the low voltage cables supplied.
If you cannot PWM regulate the fans then please use the supplied resistor wires, tagged as 'low-noise' adapters. this will prevent the fans from spinning/rotating at the full 1500 RPM, and will restrict them to a silent 1200 RPM instead.
Connect the fans 'direct' to the PSU , using a molex to 3pin fan connector with the 'low noise' adapter.
Your fans will spin constantly, but you will be able to see if the mobo is at fault.
Hope this helps
Thanks for the reply thing is they do work they just don't seems to work how they should right now 1 of the 2 fans is spinning the other day both was working fine i'm at a loss sometimes they work
Try plugging them into one of the other fan connectors on your motherboard, if you can't do the method i posted above ( bypassing the motherboard )
The other fan connectors will power your fans fine, you'll just lose the PWM control - which sounds like the problem atm.
