Permabanned
- 2 Sep 2011
Can someone suggest some memory kit(16 Gb) for an Asus p8 z77-v deluxe paired with an i5-3570k cpu?
Thank you.
Thank you.
Parts touched(lol) without an esd strap on.. hundreds or even thousands. Parts killed 0
I even made the last 2 pc's on a carpet
I'm very wary of second hand memory, so many people don't take any ESD precaution, an 8GB dimm has 500 million cells in it and it only takes one to be faulty. Faulty memory is often the cause of many random issues. I buy Kingson memory as it has the lowest returns, then take ESD precaution when fitting. You may think i'm OTT but i'm a software engineer who also writes neural net software, it's hard enough getting the software correct without introducing hardware issues also.
You obviously take a stable system very seriously. Are memory calculation errors something that could cause problems with your software?
Have you ever had a computer part fail or had any intermittent issues?
