- 17 Feb 2007
- Redditch, UK
I've been running Windows Home Server on a slim micro ATX ASUS P5 box, and it wasn't until recently that I realised I've only got two SATA ports on the motherboard, but I do have an eSATA out on the rear I/O plate.
I want to add another 1Tb drive (or possibly a new 1.5Tb) to expand my current set-up but I'm unsure what to do. As I see it, my options are:
The eSATA would only be a temporary measure of course, I'll no doubt be faced with the same dilemma if I used the eSATA in 8-10 months once that new drive is full.
Thanks in advance.
- Get a PCI 4 port SATA Expansion card
- Replace the mobo with a less cut down value one (and probably have the issue with WHS needing re-activation or not reactivating because its an OEM version).
- Use the rear eSATA port and route the cable into the case to the drive in the front.
Thanks in advance.
