After all that fuss went for the Antec 100 in the end just got it tonight, and its massive!!!!!!
i could probably move home in it, if it had wheels, also going to have to, butcher my PC table to fit it in
anyway hit my first problem soon into the new build none of the wires from PSU are anywhere near long enough
weather i use cable management or not, for a start ATX main power connector cables well short, built for PSU at top i suppose ...... maybe just enough room in cable management for connector blocks if used extensions but would be well tight
Also the two supplied fans cables are well short to say they new they connected to bottom mounted PSU ?
so i think I'm OK with HDD's they close by and OK with Sata to HDD's .... just need extensions to Main power connectors, extensions for fans to PSU, I'm sure u could buy ? ....... and any thing ells i not fort of yet too
would i be as well off getting new PSU ? with longer cables ?
As always any help advise welcome Webb
