Need 'Ping' help
14 Oct 2007
I am trying to run a ping test on an IP address that has intermittant network issues.
How can I ping it 500 times and then create a .txt log file once it's done?
Thanks
It'll save to wherever the command prompt is, which usually defaults to your user directory.
To save it on the desktop do:
ping -n 500 www.bbc.co.uk > %userprofile%\desktop\out.txt
Make sure that "IP address" isn't ignoring the pings though. For example, if it's a desktop running a firewall it might stop responding and screw up your results.
Thanks
You know its intermittant so why are you bothering to ping it? What are you trying to acheive? If I was you I'd loop say 20 pings (ping -n 20 ip) and put a loop in to echo out the time and date. Atleast then when (if) the ping drops you have a rough time slot. With your method if ping does drop, how will you know when?
I'd also opt to put in an increased timeout just to be safe.
