Need pro statistician help to answer question
16 Jun 2011
Cheshire
One individual has 4 teeth that are injured.
i There are 2 rare complications you can develop over time, each has a chance of 5% of developing in a lifetime
ii There is one other rare complication, the risk is 7.5% over a lifetime.
Q/ What is the percentage chance of this individual developing a complication?
Is it 7.5% x 4 = 28% chance over their life
Please explain the correct answer for this maths numpty so I can understand the field of statistics we are referring to. And thank you. :D
OP
16 Jun 2011
Cheshire
Is the risk per tooth, or per injury?
Is the second complication directly related to the first or independent of it?
Again, is it per tooth or related to the general injury?
There is only one injury, there are three potential complications which are independent of each other. :p
OP
16 Jun 2011
Cheshire
Hmmm...
There are 3 possible complications, all independent, their chance of developing is 5%, 5% and 7% over the patient's lifetime
There are four teeth damaged by one injury, with those risks above.
What is the % chance the patient will suffer complications in their lifetime?
OP
16 Jun 2011
Cheshire
The complications are pulp chamber obliteration (the root canal space closes up), root resorption (root dissolves off) and dental pulp necrosis (dental nerve dies).
The ladybird terms are for our OC mates if you are a dentist Hikari.
So there is 1 injury to 4 teeth
Each has a 5% chance of developing complication 1 and 2 and a 7.5% chance of developing complication 3.
The risks are unrelated.
So each tooth has a 16.5% chance of developing a complication over their life span.
In total the individual has 51.4% chance of developing any of the complications in 1 or 4 teeth.
Essentially therefore 'it is more likely than not' that the individual will suffer at least one complication.
Is that correct?
(My head hurts, I only count up to 32, and thanks for posting it has helped me understand this better).
OP
16 Jun 2011
Cheshire
The risks are published, a % change of those risks developing over time.
You are entirely right it is a crude estimation but the combined brain power of OCUK has determined the risk is much higher than I imagined as a maths rookie.
Believe it or not the fact that a chance of complications is 'more likely than not' is tremendously useful information for my purposes and it does not have to be perfect science - just a 'sketch'
The complications are unrelated to each other. They have different aetiologies/mechanisms.
Now stop doing maths and thinking on a Friday evening and go and frag some aliens or cruise chicks and suck face :p
It is good to be sceptical Dowie.
OP
16 Jun 2011
Cheshire
Hello
Just having a read, I cannot answer you question, perhaps Dowie can.
For my purposes I just needed to know 'it was more likely than not'.
Hopefully a maths Pro will be along sometime soon (I just do subtraction :p).
OP
16 Jun 2011
Cheshire
Hi Dowie
When there were four teeth, each with its own % chance of developing a complication how does 'to the power of four' come into it. Is there an easy way to imagine that - explain like I am 10?
Ta pod
OP
16 Jun 2011
Cheshire
Thanks for that, got it, tremendously helpful and it may interest you to know I used the information for my work.
Where do your ubermaths skills come from?
OP
16 Jun 2011
Cheshire
Another two questions from the desk of pod
Problem 1
There is a complication risk of 5%, independant complication, there are two teeth:
Chance = 1 - (0.95x.0.95)/\2 = 0.81
The chance of complication in a single tooth is 19%
Q/ What is the chance of complications in both teeth?
Is it 1/2 of 19%? So 9.5%
Problem 2
There are three teeth, two complications, all independent
Complication A has a 5% risk and requires treatment X
Complication B has a 4% risk but does not require treatment, however there is thereafter a 1% risk of treatment Y
What is the % chance of requiring treatment in 1 tooth, 2 teeth and all the teeth? I definitely cannot figure that out.
Please explain like I am 10, thanks Pod
OP
16 Jun 2011
Cheshire
Problem one is just 0.05 * 0.05
Problem two - are you saying there is a 1% chance in general or a 1% chance given the event with a 4% chance occurs?
Hi Dowie.
Don't forget the explain like I am 10 bitty.
Problem 1
How come there is no square to the power of 2? Don't understand.
So the answer 0.05 x 0.05 = 0.0025
So the chances of 1 tooth developing a problem is 0.25%? and what is the chance of both teeth developing a problem?
A 1% chance given the event with a 4% chance.
Thanks for your maths prowess, and where does it come from? I did ask a while back, I am curious.
OP
16 Jun 2011
Cheshire
Understood, thank you.
Ok problem 1 (two teeth)
Chance of both teeth developing a problem is 0.05*0.05 = 0.025 which is 2.5% chance
Chance of one tooth developing a problem is 2 * 0.05 * 0.95 = 0.005 which is a 9.5% chance
That explanation is brilliant I get it, ty.
Chance of no problem is 0.95 * 0.95 = 0.9025 which is a 90% chance
Ok Problem 2, going to have a think about that one.
OP
16 Jun 2011
Cheshire
Howdy, thanks for posting, have a look at the new problem, post #38
They are all independent risks, problem one has the individual patient has 2 teeth, problem 3 the patient has 3 teeth.
OP
16 Jun 2011
Cheshire
Lol
I have had a go and I can't figure it out. I am too confused, sorry.
Problem 1
2 teeth one patient, independent risks of 5%
So is this correct
Chance of no problems 1 - 2*(0.95 * 0.95)
Chance of one tooth out of two with problems 1 - 2*(0.05 * 0.95)
Chance of two teeth with problems 1 - 2*(0.05 * 0.05)
(Can't understand why there is no to the power of 2)
OP
16 Jun 2011
Cheshire
Both Teeth = 0.05 x 0.05 = 0.25%
Neither Teeth = 0.95 x 0.95 = 90.25%
Either Tooth (remaining option) = 100 - 90.25 - 0.25 = 9.5%
Understand that. Thank you, appreciated.
So problem 2
3 teeth, same patient, independant risks
Risk 1 5% chance = 0.05
Risk 2 4% chance, 0.04, of those 1% require treatment, chance = 0.0004
I need to figure out the % chance of the complications with the need for treatment:
No tooth complication
1 tooth comp
2 teeth comp
3 teeth comp
Is no tooth complication 1 - (0.95*0.9996)/\3 = 0.14 or 14% chance?
OP
16 Jun 2011
Cheshire
(Shh...he is very strict, don't upset him or he will make it 4 decimal placemats).
Fellas that is exactly what I needed, thank you for taking the time to post such crystal clear proofs. I am very grateful indeed. It may interest you to know that once again your uber maths prowess has benefited my professional practice and patient care.
PS
I got the point about the irrelevant consideration, 5% v the very small %, made perfect sense.
Once I have had a look if I get stuck may I post again.
