Hello all,
I have a dilemma, I hope someone here can help me with..
Up until two days ago I was happily running a
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2514
with 2x 2gig ram sticks and a GTX260 with a e6850 cpu
now the problem is the motherboard has broken and i need to replace it, my issue is with the size of the gtx260 and will any new motherboards fit it..
for example http://www.overclockers.co.uk/showproduct.php?prodid=MB-172-GI&tool=3
to me the ram looks like its too close to where the 260 would sit on that- has anyone else has this issue and which motherboard would you recommend as a replacement to the one that's broken that has space for the gtx260 in an
