Not sure where exactly to put this thread so its here... Sorry if its in a 'wrong' location.
Anyway im looking to buy new screws for my PC. Basically I have a Corsair 800D case and when changing the fans on the top of the case one of the screws lost its thread. I had to remove it by drilling it out which is all well and good but now I have a missing screw. Not a huge problem in itself only its making the case 'rattle' so now im in need of some more screws.
Only issue is I don't know what type of screw I need. They are very long screws used to hold my radiator in place but when I searched for screws on the main page it came up with all sorts of other screws but nothing that looked like what I wanted. There are two longer type of scres available but im not sure out of both which would apply to my machine. The current screws I have go through both my radiator and a set of fans and im not sure if the screws are long enough.
Any help would be awesome.
Thanks!
Thanks!
