Don't envy you - I'm in the middle of painting one reasonable sized room with a few complicated alcoves, etc. at the moment where I can't get everything out plus making best of a bad job as the paper has had it really but stripping it back would require significant remedial work for the walls
(1930 house).
Empty rooms and hiring someone else to do it would be my recommendation :O
EDIT: Working from one big pot of Johnstones trade paint white emulsion - which is pretty good goes on with one coat and touch dry in 2 hours or something, plus Dulux for the main walls which doesn't go on so well and needs 2 coats and Crown Steel Drum (gloss) for the skirting, etc. which is so so - better than the Dulux but pretty easy to mess up.
(1930 house).Empty rooms and hiring someone else to do it would be my recommendation :O
