- 18 Nov 2007
hey all
ok jumping straight in, tommorow i am purchasing a new computer practically and its the first time i have built one with all custom components. i have a budget of roughly £900 or there abounce, the site i will be using to purchase these components is ******.com as i find them best value for money.
Here are the specs i am thinking of getting
Logitech Z5500 Speakers 5.1 Surround Sound 505W RMS (definatly)
Asus Xonar D2X Soundcard - 7.1 PCI-Express (to compliment the speakers)
Zalman CNPS9300-AT PWM Aero Flower Socket 775 Processor Cooler (obviously for the cpu overclock, any advice?)
CM Storm Scout Case - 120mm and 2x 140mm Fans Included
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
either ASRock P45TS iP45 Socket 775 7.1 channel audio ATX Motherboard (any good)
or
XFX nForce 750i SLI Socket 775 (1333MHz FSB up to 1800MHz overclocked) 8 channel audio ATX Motherboard (advice between these two boards)
Intel Core 2 Quad Q6600 Energy Efficient 95W edition Socket 775 (2.40GHz) G0 Stepping L2 8MB Cache OEM Processor (i have old b3 quad and want to clock this new one to to 3.0/3.2 ghz) (will this be possible?)
CIT 750W Dual 12V Rail 12cm Fan PSU - 2x SATA 1x PCI-E (enough power?)
Kingston 4GB (2x2GB) DDR2 1066MHz/PC2-8500 HyperX T1 Memory Kit CL5 2.2V (Ram Smile )
XFX GTX260 Core Edition 896MB DDR3 or a ati 4870 1GB or BFG GTX260 OC MAXCORE 55nm 896MB (D) Dual DVI PhysX and Cuda ready PCI-E Graphics Card (cannot decide need help big time with this???)
in my current computer i have a xfx 9800gtx+, b3 quad on a p5b that wont go past 2.8ghz, also i am powering a new 42" lg hdtv tommorow.
So my questions are how does that some up and can somebody kindly answer the questions in brackets.
Will this rig overclock to 3.0ghz? and on a scale of 1-10 how good is this for a setup, Many kind regards well in advance.
or
