- 22 Aug 2003
- Bucks
I've got a Ryzen 5 3600 & RTX3070 on order and figured I should also upgrade to 1440p.
I'll be using it for offline gaming. I like my visuals but I also want some reasonable fps too.
Am I right in thinking that the 3070 could struggle with a monitor with more than 60hz?
Is 27" likely to be optimum size?
Are dead pixels such an issue/worry as they used to be?
I've got a budget of around £300 - 500.
Many thanks for any recommendations you can throw in my direction
