need some help please
27 Oct 2013
hello i have just started getting problems with my pc. i will play for a couple of hours than everything will lock up and go black screen and then "no signal" i was just curious if anyone knows any solutions on why this is happening. i also have this problem everytime i start up with my hardrive http://i.imgur.com/SSKtWYa.png
Hi Ollie,
A SMART event usually means the drive is on its way out.
You could run an Error-Checking on the drive (right-click the drive > Properties > Tools).
And d/l and use CrystalDiskInfo for a second opinion.
Also search the web for and d/l your particular drive manufacturer's (Western Digital?) error-checking tools.
Would be a good idea to back-up any files you want to keep, immediately.
Perhaps this thread could be moved by a Mod to the Storage Drives section, to increase the chances of getting better advice there.
