Hey,
I am trying to change my case from a PB case to a Antec 300, the 300 came with some wires for power etc which look different from the ones in my case, i cannot take the orignal wires out of my case because i cannot take the top off.
Now i dont know where the wires that came with the antec go on my mobo
heres some pics of the wires that came with the Antec and my mobo where the orignal wires are
Here are the wires that came with the antec, the blue/white one is the reset switch
http://img690.imageshack.us/i/wires1.jpg/
mobo picture where i think the wires go
http://img689.imageshack.us/i/mobo2.jpg/
picture of the USB and HDA cable, some reason it also has a AC97 cable attached to it (dunno what ac97 is)
http://img695.imageshack.us/i/usbwires.jpg/
picture of mobo where ive put the usb/hda cable
http://img197.imageshack.us/i/mobo1.jpg/
My motherboard is Foxconn San fransisco 2
heres a link to it:
http://support.packardbell.com/uk/item/index.php?i=spec_sanfrancisco2&ppn=PB81X06201
EDIT: For some reason the front panel USB ports and input jack for the mic/speakers dont work, ive tried rearranging the wires but it doesnt help, there's a green box where I have put the USB cable from the front panel, if I don't put it in there the machine don't start, here a little diagram:
http://img8.imageshack.us/i/moboxk.jpg/
Thank you
any help would be really appreciated
Thank you very much
heres a link to it:
Thank you
Thank you very much
