need some nice peoples help please
22 Mar 2009
Cornwall
ok, well this is quite embarrasing, i have just fitted my 2nd HD5770 as my xfire bridges came today. just ran some benchmarks, and well, realised i havent save any score with just the single card, so wondered if any of you nice people with a HD5700 could tell me what you get on these apps, and if any have an xfire setup, do these figures look right?
thanks
3dmark 06 - i7 920 D0, 1866MHz Ram, 2xHD5700, 1920x1080 (everything else on default)
3dmark vantage - i7 920 D0, 1866MHz Ram, 2xHD5700, 1920x1080 (everything else on default)
S.T.A.L.K.E.R DX11 Benchmark - i7 920 D0, 1866MHz Ram, 2xHD5700, 1920x1080 (everything else on default)
Ugine Heaven BenchmarkUnigine
Heaven Demo v1.0
FPS: 25.2
Scores: 635
Hardware
Binary: Windows 32bit Visual C++ 1500 Release Oct 22 2009
Operating system: Windows 7 (build 7600) 64bit
CPU model: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
CPU flags: 2700MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT
GPU model: ATI Radeon HD 5700 Series 8.690.0.0 1024Mb
Settings
Render: direct3d11
Mode: 1920x1080 8xAA fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Unigine Corp. © 2005-2009
I don't have my scores at hand but search for the 5770 and stalker benchmark threads for comparable results.
No need to take a card out, just disable crossfire in the CCC and retest.
ok sorted, so here are my results, do they look alright for xfire?
3dmark 06 - i7 920 D0, 1866MHz Ram, 1xHD5700, 1920x1080 (everything else on default)
3dmark vantage - i7 920 D0, 1866MHz Ram, 1xHD5700, 1920x1080 (everything else on default)
S.T.A.L.K.E.R DX11 Benchmark - i7 920 D0, 1866MHz Ram, 1xHD5700, 1920x1080 (everything else on default)
Ugine Heaven BenchmarkUnigine 2xHD5700
Heaven Demo v1.0
FPS: 25.2
Scores: 635
Hardware
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Ugine Heaven BenchmarkUnigine 1xHD5700
Unigine
Heaven Demo v1.0
FPS: 14.2
Scores: 359
Hardware
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Well I don't do all that benchmark stuff but I did the unigine demo and my CF score is exactly the same as yours.:)
cool, so all should be setup right, first time i have done CF so wasnt 100% sure it was working right. weird how yours are vapour x and mine are the cheaper club3ds and they get the same scores though.
Mine are running at stock 5770 speeds. I will overclock them when I need the extra performance.:D
out of interest, i was contemplating getting a HD5850 instead of the 2 HD5770 in CF. dont spose there are any similar benchmarks from HD5850 owners to see how similar they are as there seemed to be conflicting opinions when i ordered. cheers.
