Hi All,
Just bought my first house last week and after being in there a couple of days I've noticed a few bits and pieces which could do with sorting.
1) Toilet flushing. Using the smaller of the two buttons on the toilets seems to work fine. However when pressing both together it then feeds water constantly into the bowl and then tops the tank every few seconds...it's rather annoying.
2) Leaky basin. The water takes a little time to empty out of the basin and some is dripping onto the floor. I've had a little play but not much luck.
I'm happy to post some pictures if anyone's willing to help, or if anyone could recommend a site where you can get decent tradesmen without being ripped off, as I can only imagine these are small(ish) thinks to rectify.
Cheers
Swain90
Cheers
Swain90
