Need some storage
18 Oct 2002
Cambridge
I need to replace my failed external hard drive. Have decided to go for 3TB but i'm having issues finding a cheap one with an on / off switch. It won't be used very often but i don't want to have to keep unplugging it all the time. Any recomendations?
you could try the mb559u3s... but as your looking for a cheap one, it may be a bit more than you are looking to pay but it's worth the money. So it depends what your after in that department.
Well the product I have mentioned would cost about £54, that's without a new HDD so this might be more than you want to spend, but the quality is worth every penny and it's an very attractive product.
