Need some website help
25 Nov 2006
Birmingham
Hi,
Im trying to intergrate a image uploader but it wont work the one im uploading seems good but i get this error here. if this cant be fixed It would be great if someone can direct me to something similar and if possible for the uploader to allow extensions from MS word, excel ect not really botherd about the word and exel stuff but it would be nice to have. I just uploaded this and set the settings in the php file to what I wanted. This is the settings in the php code.
PHP:
$extlimit = "yes"; //Do you want to limit the extensions of files uploaded
$limitedext = array(".gif",".jpg",".png",".jpeg",".zip",".rar); //Extensions you want files uploaded limited to.
$sizelimit = "yes"; //Do you want a size limit, yes or no?
$sizebytes = "20000"; //size limit in bytes
$dl = "www.multi-game.co.uk/uploads/"; //url where files are uploaded
$absolute_path = "http://www.multi-game.co.uk/uploads/"; //Absolute path to where files are uploaded
$websiteurl = "www.multi-game.co.uk/uploads"; //Url to you website
$websitename = "Multi-Game Upload Site Please Use This Appropriatley File Retention Is A Month For All Files Other Than Images";
switch($action) {
default:
echo"
<html>
<head>
<title>Upload Or Download</title>
</head>
<body>
<a href=$PHP_SELF?action=upload>Upload File</a>
 <a href=$PHP_SELF?action=download>Download File</a>
 <a href=$websiteurl>Return to $websitename</a>
<br><br>
Powered by <a href=http://www.zachwhite.com/>PHP Uploader Downloader</a>
</body>
</html>";
break;
case "download":
echo "
<html>
<head>
<title>File Download</title>
</head>
<body><a href=$PHP_SELF?action=upload>Upload File</a> <a href=$websiteurl>Return to $websitename</a>";
$list = "<table width=700 border=1 bordercolor=#000000 style=\"border-collapse: collapse\">";
$list .= "<tr><td width=700><center><b>Click To Download</b></center></td></tr>";
$dir = opendir($absolute_path);
while($file = readdir($dir)) {
if (($file != "..") and ($file != ".")) {
//Download files with spaces fix by Kokesh
$list .= "<tr><td width=700><a href='$dl/$file'>$file</a></center></td></tr>";
$list .= "</table>";
echo $list;
echo"
<br><br>
</body>
</html>";
break;
case "upload":
echo"
<html>
<head>
<title>File Upload</title>
</head>
<body>
<form method=POST action=$PHP_SELF?action=doupload enctype=multipart/form-data>
<p>File to upload:<br>
<input type=file name=file size=30>
<p><button name=submit type=submit>
Upload
</button>
</form>
<br><br>
</body>
</html>";
break;
//File Upload
case "doupload":
$dir = "dir";
if ($file != "") {
if (file_exists("$absolute_path/$file_name")) {
die("File already exists");
if (($sizelimit == "yes") && ($file_size > $sizebytes)) {
die("File is to big. It must be $sizebytes bytes or less.");
$ext = strrchr($file_name,'.');
if (($extlimit == "yes") && (!in_array($ext,$limitedext))) {
die("The file you are uploading doesn't have the correct extension.");
@copy($file, "$absolute_path/$file_name") or die("The file you are trying to upload couldn't be copied to the server");
} else {
die("Must select file to upload");
echo "
<html>
<head>
<title>File Uploaded</title>
</head>
<body>";
echo $file_name." was uploaded";
echo "<br>
<a href=$PHP_SELF?action=upload>Upload Another File</a>
<a href=$PHP_SELF?action=download> Download File</a>
<a href=$websiteurl> Return to $websitename</a><br><br>
</body>
</html>";
break;
Thanks
