need SSD 64gb for HTPC help.
9 May 2009
hi all after a very reliable SSD for my htpc that i am currently building and wanting some help as i have never bought one befre and wanded some tips and whats the best drive to get.
it does not have to be the fastest but it does have to be reliable.
thanks
Just to be clear - what do you need it for specifically?
You mentioned reliability over speed, and seem to be looking for a small (64Gb) drive - is it just for the OS?
Are you thinking SSD just for the low noise, energy and heat?
Otherwise a good, premium-brand small HDD might do you (or a USB drive on an internal header, for some boot options).
Using it for a htpc with just the os and xbmc on it and it's library.
But i want no heat and noise. Would loke fast wake up times when the htpc is in sleep mode.
