Need to backup my lappie hdd to a usb drive HELP!!
8 Dec 2004
Paignton, Devon
Hi, I need to do a complete backup of my lappie hard disk drive to an external usb hard disk drive so i can re-install the OS, I can't do this in windows as it is obviosly using some of the folders and files for windows, How can this be done, Would i need a third party software and if so what?
Thanks
If you're going to reinstall the OS then you don't want a full disk image backup because if you restore that you'll overwrite the new OS install with your current one which defeats the purpose of the whole exercise.
If you do an OS reinstall then you'll need to reinstall all your apps as well so all you really need to backup are things like My Documents, all your favourites/bookmarks, emails and any other media or files that you need to keep.
I really need a full backup of the hard disk drive as i have proggys to make sure i do not miss anything off, The wife tends to put pictures and doc's all over the place and i don't really want to lose any of them so what i wanted to do was back the whole hard disk drive up then do a fresh installed, Then i was going to get the wife to go through the backup'd hard disk drive and get everything off she needs, What i really need to do is clone the hard disk drive to the external drive.
OK. Well the files that are locked by Windows you needn't be too bothered about, providing you don't expect to ever want that installation bootable again. You can use e.g. RoboCopy (or even XCopy) with appropriate switches to copy all the accessible files onto another disk.
Alternatively, if you want the ability to return to your previous install if required, I'd recommend you to get Acronis TrueImage. Take a full backup image of your system, verify it, then only reformat/reinstall your laptop. Then install Acronis again, which will allow you to mount the backup image as a drive on your newly installed PC, allowing you to manually copy over whatever you want.
Aside: In some instances recently I've when recovering/reinstalling a PC with many bookmarks, emails, connection entries and so on, used the File and Settings Transfer wizard to transfer all that with less hassle. The biggest problem in general with the idea of using the wizad of course is that you need 2 pc's to use it, which is not the case wehn upgrading one machine. However what I've now successfully done a couple of times to get around this problem is effectively to do the process twice -- You do it once onto a clean XP install Virtual Machine running on VMWare I've got on hand for just this type of event (not even activated or anything), then, I reinstall the machine actually being cleaned up, after which I again use the File and Settings transfer wizard this time going from the VM to the now cleaned up machine. It's a little bit of hassle (but seems less hassle than trying to manually migrate all user settings and files particularly if they're non-trivial as you can basically set it off to go and have a cup of coffee while the machine works.)
Aside2: VMWare actually has a tool that can convert a physical machine into a virtual machine. This in theory would allow one to take an "image" of the machine, as a VM, then boot the VM, and directly transfer the files and settings from the "old" PC now in the VM, to the new freshly installed physical PC. However, my one attempt at this was scuppered by Windows activation. Very very annoying.
dd should do the job. Can be found on pretty much all linux live cds. It's command line and you might need to do a bit of searching to find instructions, but it's very easy to use.
Yes, this is an option, although you'd need to be prepared to learn a few things about Linux and the command line, and have some patience, if you want to take that route. If you do decide to go there, I can give some pointers. (For one, you'd need to dowload a suitable Linux liveCD. I'd recommend TRK.) Post back if you're interested.
I have just finished restoring an image to my laptop from a usb drive, basically i changed from a 100gb 5400 rpm drive to a 100gb 7200 rpm drive, I used Acronis bootable CD to create a backup image of the entire drive onto my external 50gb drive, swapped the twoo 100gb drives over and rebooted from the Acronis CD and ran a recovery to the new drive, took a few hours but its all working again, and i have both XP and Vista Dual boot via Two partitions on the drive :)
