- 7 Mar 2005
- LU7
Yesterday a switch in one of the classrooms at work had two cables from two network sockets plugged into it thus causing a loopback which took our network down for half the day. It is the second time it's happened in the last year and it is because each classroom does not have enough network sockets and so we've historically used switches in each classroom to expand the number of computers that can be connected to the network.
There is a classroom where CAT5 cables are hanging down from the ceiling and are directly plugged into computers and are not terminating in a network socket. This kind of thing is something that I've wanted to fix but haven't had the time as yet. The idea of network switches is something my previous boss did and whilst it works it obviously isn't the right way of doing things.
I'm now planning to make sure that each classroom has plenty of network sockets spread around the room so that we can eliminate the switches in each room and prevent crazy network problems due to loopbacks. I need to learn how to wire up faceplates and CAT5 cables to do this. Following on from this thread am I right in thinking that the following faceplates and back boxes are the correct products to be buying to learn on at home?
CAT5e double socket faceplate
Double socket back box
Are there any other products I need to buy to help me both learn how to wire all this stuff up and then use when I work on the classrooms? Do I need any of these cable testers or are there better models out there? I've already bought a crimper that bledd. recommend in another thread. I'm pretty sure that there's a box of CAT5e at work somewhere but I might need to buy RJ45 plugs and boots. I probably could also do with a cable stripper.
Is this the one?
