Need to recover DATA
30 Jul 2004
East Sussex, UK
Afternoon guys.
I've just had an 80GB die on me. The drive it self is fine. However, the mainboard has a chip that fried on it. Just started smoking! :eek:
Anyway to recover music off it? if I replace it with another board, does it have to be the same make/model/size/ect hard drive?
Ice On Fire said:
Afternoon guys.
Is this a chip on the drive PCB that's fried? If so you should be able to swap boards with a donor drive but it'll need to be an identical drive - make, model, size and revision if possible.
1337_KR3W said:
put the hdd as a slave in a 2nd machine and you can copy all the data from it
If the drive electronics are fried then it'll need the board replaced.
Yes, a chip on it has a big hole in it now, where it burnt out. :(
