Need to swap out with larger HDD in my NAS running RAID5. Is it plug and play?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
My ancient Netgear ReadyNAS 104 has 4 HDD in it, it has 4 x 3TB drives and it is running out of space.
I want to replace them with larger drives and the latest firmware suggest it doesn't have a limit but my bank balance does so going to do it slowly, perhaps 2 drives at a time with
It is running RAID 5. I forgot what that means, I set it up over a decade ago, so my question is can I remove one of the drive when it is powered on and replace with a larger on. Wait a few days for it to rebuild, then replace another?
Or do I turn it power it down first and swap?
EDIT - It is running X-RAID.
Although hot-swap is probably supported, I would power the NAS down to swap disks. This is purely personal preference so check if hot-swap is supported and do whichever you please.
Yes, you can replace one drive at a time but, in terms of disk usage X-RAID seems very similar to RAID5 so rebuilding after a drive swap will put quite a lot of strain on the drives. If they are ten+ years old I would worry about one failing during the rebuilds which would probably mean losing the data. I would strongly recommend backing up your data to an external device, replacing all the drives at once then copying it back.
I don't have enough spare storage externally to fit the 8TB in this NAS, I have the 4TB SSD that I am going to use for my new Mac Mini that is currently empty.
I think the plan is
1 - Delete as much junk first as possible
2 - Move the rest into my Drobo
3 - Back up the remaining data into an external SSD temporarily.
4 - Remove all the drives
5 - Put in Two 8TB drives
6 - Move the data from the SSD back in
7 - Add 2 more 8TB drives later down the line.
Also separately do a clean up in my Drobo too.
Or new plan.....
1 - Clean up, free space for now, enough to save up to...Point 2..
2 - Get new NAS with 4 bay, 2 x 16TB drives first.
The price differences will just be the NAS....and I get to get a faster connection too.
Old plan would have worked but new plan is certainly better as NAS technology has come a long way in the last decade. If you're not planning to run loads of apps then I suggest the Asustor DRIVESTOR 4 Pro Gen2 (AS3304T v2) would be a good choice otherwise moving up to the Nimbustor 4 Gen2 (AS5404T) would be my pick. I admit I'm an Asustor fanrinkli but it really does offer the best value hardware of the three major NAS brands.
I don't plan to run any apps at all, might be a cloud server or a Plex server at most.
I have 4x 10TB WD Reds that I want to sell soon. Would they be of interest? Details here:
  • 6 years old so no warranty but no issues with any of them so far
  • CMR
  • Start/stop counts: ~12k
  • Power on hours: ~55k
  • All error/sector/retry counts: 0
  • ZFS scrubbed once a month with 0 errors
P.S. I would also agree that copying the pool over to new disks is a better plan than replacing one drive at a time: much less strain on the drives and lower risk of failure. I did this recently and used my desktop to hold the new disks temporarily for the data transfer before swapping them out. Just about had enough SATA ports!
  • CMR
Thanks but I’ve managed to clear out 2.5TB over the weekend so I’m okay for a year or 2 now.
