Need two PCs built.
11 Feb 2007
London / Essex
Looking for a gaming rig 1440p, mainly Cod, fortnite and other esport titles.
Approx £600 can it be done?
Already have keyboard, mouse and monitor.
And a office PC that can run two 4k monitors.
Approx £350.
A cheaper motherboard is possible, especially if you don't need wifi and are willing to go H610. CPU can be had a little cheaper too.
RX 6600 can cope with most games at 1440p, but obviously the lifespan at this resolution is limited, especially with AAA.
My basket at OcUK:
Total: £676.84 (includes delivery: £11.98)​
The office PC I'd look at a 4600/4650G prebuild, or something along those lines, they're plentiful and will be cheaper than anything you can spec yourself.
My basket at OcUK:
The rx 6600 will it run games at higher settings? As I can rescue a coolermaster 600w from there old pc (6th gen i3)
Was thinking that would one of those tiny mini micro units cut dual 4k the 1l units?
no, those UHD630 igpus can only handle 1x 4k monitor
you'd need an el cheapo gpu to power the 2x 4k monitor, or one that already has a gpu inside
you'd need something like a 1030 to run 2x 4k
(the alternative is to have one monitor running off the igpu and the second monitor running off a gt 710 or something mediocre)
Shame would have made for a neater setup.
For competitive gaming @ 1440p? No. Not unless the game is old or not too demanding. This might be of interest:
It's an entry level GPU and most suited to 1080P gaming tbh, while it will run many games decently at 1440P you're probably looking at lowering the settings.
If you can save some cash by reusing a decent PSU, look up the XFX RX6750XT Speedster QICK 319 which can be had for £299 currently, much better card.
Just had a look at the old rig and it has the following
I3 6100
Gigabyte z170 gaming 7
16gb 3000 corsair lpx ddr4 (2x 8gb)
2tb crucial p3
Gt730
Some corsair 280mm aio
Coolermaster 600w psu
Nzxt s340 razer case
Tbh that should be fine for an office PC and a couple of monitors.
Think the mobo is on the way out as it no longer outputs video hence the gt730 and the usb ports drop off randomly which requires a restart, reason for the upgrade.
Was originally shared by my brother (hybrid working from home) and nephew doing his school work now being in college they both need their own setups.
You could reuse most of it tbh, swap out the mobo and cpu for something like the following:
My basket at OcUK:
Total: £159.98 (includes delivery: £0.00)​
Spend the extra savings on a better gaming rig.
You could likely find a A520 motherboard for less, but OCUK don't have any in stock currently. Might be cheaper Intel options too, I'm sure someone else can point you toward that.
My basket at OcUK:
Could work they would also like to reduce the footprint for the office rig I'll have a look at smaller case
Just seen this used Dell OptiPlex Mini 7000 has the uhd770 would that be able to run two 4k displays?
