Need VGA driver help!
14 Sep 2005
All over.
Hi, I've got a Acer Aspire 5021 laptop. I've just used Driver Cleaner to clean the driver as I wanted to update to Catalyst 6.9. But I need the Standard VGA driver which I can't find anywhere.
There's nowhere on the Acer website for the chipset model. There are VGA drivers on the website however, it says that I need to install the Standard VGA driver before it.
Anyone know where I can download the standard video driver?
Thanks.
If that is the driver for your laptop and you can't get the 6.9 Mobility ones to install then PM me, I have the standard 6.9 ATI driver either with or without the dreaded CCC for install onto that chipset (I think). PM should be in trust.
