Need water cooling help!
19 Jan 2006
Guernsey
Hey guys!
Just need some urgent help.
My computer just shut down randomly before and wouldn't power back on.
I took off the side to find that my tubes were empty! I dont have any distilled water or de-ionized at home.
Do you think britta filtered water which has been boiled will be okay for a temporary solution?
Thanks
Should be fine for a while TBH. The worst part is if you have hard or very alkaline water, but the filter should take most of the impurities out if its new.
