Need watercooling!
I used PTFE tape on my first watercooling build before realising that thats what the O-ring done for me! Doh!
Back to the topic, as above the blocks for the 295's are £100 each so no way of getting this all under £250. That amount will only pay for a CPU only loop or a single 295 loop.
Will need two loops as well so double everything spec wise...
Yea, Ive never used the PTFE tape, just the rubber o-rings and Ive been fine.
But yea, water cooling all those parts is gonna get expensive!! Plus the fact you didnt know what a rad was shows you should follow these guys advice and do a bit of research and reading up first, will really make things easier for you :)
Plus you didnt say what case this is going in (or I just missed it). Would really effect what rads we'd reccomend, in this situation, size is everything :p haha
