I have started to overclock a bit and now need to replace the stock CPU cooler I have.
I would like to look at a water cooled option, and like the look of the Corsair "ready made" options, I am a fan of the brand; have been for a while.
What I am not sure about is where I should place the radiator, what size of radiator I should get and also what position the fans should be in?
My current setup is below, I have a Corsair 275 case:
So I have two fans at the front blowing in and then three blowing out - two at the top and one at the back.
If I go for something like this:
My basket at Overclockers UK:
What size would I be best to get and where would I be best to place it? Do the fans go in front of the radiator and so they blow the air through the radiator and out of the case?
Appreciate any help, just not sure how these work for fans/size etc.
- 1 x Corsair Hydro Series H100i Platinum SE Addressable RGB Performance Liquid CPU Cooler - 240mm (CW-906= £149.99
Total: £158.69 (includes shipping: £8.70)
