Nero Problem
23 Nov 2005
London
Hi,
Everytime i go to create a dvd on nero it gives me a problem saying:
"unable to insert <video name>"
this happens with any video or any type of video that i try and its only started happening recently..if any knows how to fix this problem please let me know :)
11Gb on the drive nero's installed and its the latest version (Nero 7)
this only started happening recently although im not sure what caused it which is the annoying thing...
well this started happening when i had nero 6..so installed nero 7 thinking maybe that would solve the problem...
it's and .avi that im trying to add..
i get the same thing with that program too :/
could it be some kinda codec that could be causing the problem?
Yes what codec are you using? I'm assuming your using nero vision express and not trying to put an avi file into a video ts folder in burning rom?
yeh im using vision express...
well ive got a few installed..k lite codec pack (i definatly know this one isnt causing any problems)
although ive noticed that when i open a folder with videos in it a little icon that looks like a film strip comes up in the task bar...ive tried to click but it shows up then disappears within a second so i can never make it in time to click it..i get the feeling that that is the problem....
