Ol!ver said:
I'm using V2, so don't know if it makes a difference.
I've had problems with Netgear firmware for my DG832Gv2 too.
When i bought my router I immediately upgraded to what was then the latest firmware version 2.10.09 (beta). That has served me well for the past year
and a half.
Recently I saw a thread on this forum about Netgear firmware which reminded me to update my own. I downloaded the latest 3.01.25 from the Netgear site but after doing so my line kept losing sync randomly and fairly frequently. I decided to try the other recommended firmware 2.10.22 but found the problems persisted.
I then rolled back to my dated, but trusty 2.10.09 firmware and the disconnections and loss of sync stopped immediately. Personally I'm going to stick with this but just FYI there are two beta versions of Netgear firmware floating around at the moment:
3.01.29 - which was scheduled for release but then pulled due to "issues in testing in the UK" whatever that means?
3.01.31 - currently in beta and supposedly available from Netgear support on request though it has known firewall bugs that open some ports by default, so perhaps best staying away from this one.
