netgear DF834 problems: login into firmware
rjk
rjk
Caporegime
8 Aug 2007
so i have the password
i go to the ip address of the router
it gives me the prompt - i type in my user and password
then it refreshes and asks again on constant loop
will not access the web interface on any browser
plus i get page load errors on all my tabs at the moment as well as generally terrible performance all round
anyone know why this password loop is occuring?
i can fix it after that - just cant get access!
sounds like the password you are entering is wrong
have you tried a factory defaults reset ? holding down on the reset button for 30 secs ?
then login should be admin/password I think
i have checked the password loads of times
it is correct
i reset to default and it is still doing it
can access from my laptop
but not my main rig
As C64 said, it sounds definitely like you're using the wrong username/password. Hold down the reset button for 20 secs to hard reset it, and then Google to find out the default username and password (admin and password I think...)
Sorry just saw your other post... if you can access it from your laptop but not your main rig... well, there's something wrong with your main rig :p Try a different browser?
Check in notepad that when you type in the password that is exactly what is appearing, sort of a weird request I know but it there's a prob with the keyboard then this will show it, then do the same on the lappy.
Sounds like your connection is dropping out when trying to access the web,
the givaway sign here is the page load errors.
Are you trying this wireless, if so try wired.
If not you will have to check your internet settings.
Not much help i know, but this sounds like the same problem i had when i first switched to broadband.
