Network Adapter For PC has constant Yellow Triangle
27 Aug 2025
UK
Recently I have been struggling with spotty wifi connections, this has only started as of recent and already ruled out my wifi, after a bit of research I came to the conclusion that it had to do with either my Network adapter or my Ethernet Connection, I found when I went to look at whether my network Ethernet adapter needed an update it had a yellow triangle over it, people suggested uninstalling and restarting my PC to fix it but sound still the issue persisted even after working for a bit. Even now I’m still confused and wonder if there’s any troubleshooting or advice anyone could give please?
Are you connecting by ethernet or wi-fi?
Have you tried going to the support page for your motherboard and manually downloading and installing the wif-fi and/or ethernet drivers?
I’m currently connected through Ethernet from a Wifi Extender, also thank you for the suggestion I will begin to have a look at the support page for my Motherboard
Sounds more like a problem with the wireless side of the wireless extender. If the wireless connection between that and your router is poor then that would show the limited connectivity warning triangle.
