Hi all i have a network cable run of about 30m which has a cat6 cable ran it at the moment. It will only connect at 100mbit i have tried different devices and tried a cable tester which is showing all pairs / cables working. Any ideas? Thanks!
Hi Mr Pink. Its a completely un-managed switch so unfortunately i cannot manually set it at all.
I did try plugging it into my computer rather than into the switch. The computers network card light did not come on for about 20 seconds then it connected at 100mbit. I can only guess it was trying to connect at gig an failed.
Is the cable new/old? Have the Ethernet ports been empty for a long period of time?
Reason I ask is that the connection pins on the cable as well as in the port can get a fine layer of dust on them which can cause a not so solid connection.
Hi thanks for the reply's. I have a crimp tool that i got with my cable tester, i used it on the connectors even though they were already crimped / sealed. It seems to have done the job! have a gig connection now!
