network card working and internets connected but cannot load anything
11 Oct 2008
Hey,
My internet has stopped working on my acer netbook (win8). It connects to the router and says it has local and internet connection however when I open my browser it just times out.
I have updated the drivers and tried an external wireless adaptor with no luck.
I have also checked the firewall is open and ran an anti virus ad adware.
Any ideas?
pinging the ip number worked, the bbc one did not.
Said "ping request could not find host".
I have tried it on a few routers and different internet connections as well with no luck if that helps.
Could be the old winsock problem (xp used to get it all the time, not sure on windows 8).
Go to command prompt and try the following commands,
netsh winsock reset catalog
netsh int ip reset reset.log
Restart after trying them. Fingers crossed.
