Permabanned
- 7 Jul 2005
- Suffolk
i have been trying to set up a network between 2 pc's connecting thru a router. 1 of them is a laptop the other is a desktop pc, i can get both to connect to the net using the router no problem but i would really love to be able to access files on the pc from the laptop.
i have set both the pc and laptop to the same WORKGROUP
the pc's IP is 192.168.1.3
the laptops is 192.168.1.2
to simply get files from the pc with the laptop do i just type in the explorer 192.168.1.2 ??
when i do this it comes up with page not found.
i have windows xp
the router im using connects to the pc thru USB and the laptop connects to the router with a straight through ethernet cable.
thanx
i have windows xp
thanx
(think i was using / instead of \
