Hi all.
given my current living situation and circumstances, I have to make do with things.
I have a room which will have my main computer. I also have a wireless router of mine.
in another room is the cable modem which is also wireless. I don't want to use that router due to features etc... and because I do a lot of technical stuff, my own router is set up the way it needs to be.
there is no way I can move the cable modem into my room unless it get rewired.
I was thinking of using a network powerline adapter which:
- will plug into the room which has the cable modem
- will plug into the room where my computer is and have that plugged into the wireless router I have
the main computer must be wired so that will be plugged into my wireless router in the room.
questions:
how fast are these network powerline adapters in comparison to a direct wired connection to the router?
how secure are they?
which is recommended?
what about interference?
questions:
